TwinTurbo.NET: Nissan 300ZX forum - 60 is fine DRY without injectors. 100 is fine with WET
Subject 60 is fine DRY without injectors. 100 is fine with WET
Posted by SeedyRom on September 13, 2001 at 6:45 PM
  This message has been viewed 25 times.
In Reply To It is my understanding... posted by Jackie Chan (RH2-SWEET!) on September 13, 2001 at 06:30 PM
Message And no injectors. Since wet supplies the fuel with it, you don't need bigger injectors. In both situations, a degree colder plugs should be used as well as the timing retarded to 13 degrees or so to be safe.
The 60 shot dry can be upped to 100 shot safely with TT sized injectors and the 100 shot wet *could* be upped more as well...but it's uncharted territory and would probably be too much for some other stock NA parts. 100 should be the maximum realistically. That is, unless you are fully built, understand NOS completely and use the car for racing purposes. For 99.99% of us, 100 is the most.
Vote on my Z on www.cardomain.com! Fords are killing us!
Zheaven.com has a new, FASTER server! Latest update includes full writeup on the 3rd annual L.A. Sports Car Canyon Drive 07/30/01 -- Click my Z below to enter.
